Sponsored by:
Sponsored by:
How do i tighten the alternator (serpentine) belt?
Old 04-23-2010, 01:47 PM
ahmad89's Avatar
Default How do i tighten the alternator (serpentine) belt?
I have a 98 accord LX and somehow the bolt that holds the alternator came half way out and i cannot align the other side so i can put the bolt in. How do i loosen the belt so i can put the bolt in?
Old 04-23-2010, 01:48 PM
deserthonda's Avatar
I4 or V6??
Old 04-23-2010, 02:01 PM
ahmad89's Avatar
I4, there is a bolt right below the alternator i think it's the auto tensioner but it didn't do anything and it's loose
Old 04-23-2010, 02:24 PM
Which bolt are you talking about? 4, 5, or 6?
Old 04-23-2010, 02:35 PM
ahmad89's Avatar
Number 6, the upper mounting alternator bolt it comes out in between the power steering belt, i see in a manual i just found that there is an adjusting bolt but i tried to loosen it and nothing happened.
Any thoughts on how i can put that bolt back in?
Old 04-23-2010, 02:47 PM
you need to loosen up the 12 mm nut ( # 10 ) in the picture, also loosen up the 14 mm bolt ( # 6 ) then back off 10mm bolt ( # 5 )
once belt is loose,( or slip the belt off ) it will make it easier to move the alt around and do whatever you need to do
Old 04-23-2010, 02:57 PM
ahmad89's Avatar
Ok i will give that a shot after i eat, thanks.
Old 04-23-2010, 03:43 PM
ahmad89's Avatar
It worked, after i loosened the nut, #10, the belt loosened and i was able to screw in the bolt completely and re-tighten the belt. Now it does not squeal when i start it up or have the a/c on. Thank you all very much for your quick replies.
Imonlybonnie
11-18-2013 11:48 AM
john_pyro
01-10-2013 11:10 AM
Michelle
03-02-2012 06:36 AM
aking
04-04-2011 11:19 AM
Amtrak288
12-29-2007 01:18 PM
Quick Reply: How do i tighten the alternator (serpentine) belt?
