Welcome to the Honda Accord Forum - Honda Accord Enthusiast Forums.
If this is your first visit, be sure to check out the FAQ by clicking the link above.
You may have to register before you can post: click the register link above to proceed.
To start viewing messages, select the forum that you want to visit from the selection below.
RE: how to remove an old ignition switch to replace it
This is for a 6th gen, but it should be similar for you.
- Remove the top and bottom steering column covers (3 screws on bottom, clips on top)
- Unscrew the 2 screws holding the switch in (it's on the left side of the column attached to the end of the key cylinder)
- Unplug the ignition harness from the driver kick panel fuse box
- Remove the switch.
To install
- Slide the new switch over the the square shaped end of the key cylinder.
- Plug the harness in.
- Put the covers back on.
I typed it fast, let me know if you need more detail.
If you want to remove the key cylinder and the switch as a complete assembly is to a.) cut slots in the 2 shear bolts holding the cylinder to the steering column and remove them with a slotted screwdriver or b.) drill the bolts out. I've done B and it's difficult considering the limited space you have to work with. If I ever had to do it again I'd try A with a Dremel tool first.
They're shear bolts. The bolt heads are designed to shear right off at a certain torque, most likely to prevent tampering with the ignition if you're car is in the process of getting stolen, but I really have no clue. All I know is that when I removed the ignition assembly to sell, it was a major PITA to drop down the steering column to get a drill in there. Dremel with a cut-off wheel should do the trick.
The bolts look like big rivets on either side. Just cut slots into them s a flat head screwdriver will fit. If you cut the bolts you're just, in theory, shearing them again and you'll have to extract them outside of the car. I've done it and it's not easy.
Honda and the Honda marquee are registered trademarks of the American Honda Motor Company, Inc. Neither American Honda Motor Company nor its subsidiaries or affiliates shall bear any responsibility for HondaAccordforum.com content, comments, or advertising. HondaAccordforum.com is not affiliated with American Honda Motor Company in any way. American Honda Motor Company does not sponsor, support, or endorse HondaAccordforum.com in any way. Copyright/trademark/sales mark infringements are not intended or implied.
