Sponsored by:
Sponsored by:
how to remove timing belt top cover
Old 01-22-2011, 10:50 PM
darkgreen18290's Avatar
Default another problem....
A cautionary comment. Be very careful when working near the open upper timing belt cover. If you drop anything into the timing belt cavity, there is good possibility of damage if object is not removed. Removal is a big job requiring removal of cranshaft pulley and lower timing belt cover.
The front bolt of the TB upper cover is lost thread, probably I tighten it too much last time I remove. How can I get it out? Any idea.
Old 01-23-2011, 09:15 AM
Two suggestions:
1) Use a dremel tool to cut around the upper timing belt cover to release the cover. Once cover is removed (find a used replacement), I think you can remove bolt by prying (grind a slot in a cheap chisel and bend as necessary) underneath and turning at same time.
2) Grind bolt head off to allow cover to be removed. Use vise grips to grab remaining bolt stub and pull/turn to remove. Hopefully, it's the front lower bolt and not the one near the camshaft sprocket, which will likely interfere w/ removal.
Option 2) seems less damaging. Worst case and you can't remove the bolt. Just grind head flush and install cover w/ remaining bolt.
If you can get the bolt out, you'll need to drill, retap, and install a thread insert to fully restore. Best leave this to a shop w/ experience. This is not a job to "learn".
You might check the removed bolt threads. If they are damaged, they may be the source of the problem rather than the tapped hole threads. New bolt may work OK.
mikek
08-06-2019 07:37 AM
john_pyro
08-04-2019 05:06 PM
Jethead102
05-07-2013 12:14 AM
claggie
01-13-2010 09:03 AM
Tony1M
04-01-2007 05:42 PM
Quick Reply: how to remove timing belt top cover
