How To Replace A Rear Lower Arm Bushing On a 97 Accord LX
Old 10-13-2008, 02:11 PM
spudman49
Default How To Replace A Rear Lower Arm Bushing On a 97 Accord LX
Fellas, just asking a question. First off I snapped off the bolt head to the rear lower control arm holding the strut. Had to drill out the bolt as she was in like it was threaded. Because of the angle, could not drill it straight, so it went in at an angle. Now I want to change the whole bushing to the control arm. Question is what kind of puller, etc. do I need to push out the bushing. The drivers side bolt came right out with a air impact wrench and I had a new strut put on in about 40 minutes. Passenger side took me about 7 hours of drilling banging and die grinding. Now the bushing inside the rubber is drilled off center and I want to replace it. I need some technical help on how to remove the bushing. Thanks The Spudman
Old 10-13-2008, 02:47 PM
falkore24's Avatar
Default RE: How To Replace A Rear Lower Arm Bushing On a 97 Accord LX
Drill/torch the old one out and replace with Energy Suspension polyurethane. The outer metal casing will have to be cut very carefully .... my buddy and I used a mini belt sander and a hacksaw blade.
jkowtko
08-27-2014 05:29 PM
Half-fast
01-19-2014 07:50 AM
Colondo
01-25-2013 09:58 AM
jkowtko
10-06-2012 09:22 PM
mtnbay
07-20-2008 03:22 AM
Quick Reply: How To Replace A Rear Lower Arm Bushing On a 97 Accord LX
