Sponsored by:
Sponsored by:
How to use seafoam to clean egr
Old 06-05-2007, 09:48 AM
tony11's Avatar
Default How to use seafoam to clean egr
Hi, where is the post in DIY to use sea faom to clean the carbon build up?
before I start sucking it through any vacuum hoses I want to make sure I do it right and can ID where I need to pour this.
I plan to put a can in the gas tank, but want to try running it thorough the vac. lines as well.
So how do I do it?
Thanks
Old 06-05-2007, 01:30 PM
Deleted User
Default [Deleted]
[Deleted by Admins]
Old 06-05-2007, 03:51 PM
tony11's Avatar
Default RE: How to use seafoam to clean egr
Thanks for the tip. can you describe the hose for the brake booster in more detail?
I want to use this hose if possible. Where in the engine compartment is it? bythe air filter? or by the vacuum box next to the fuel filter?
Old 06-05-2007, 04:54 PM
Deleted User
Default [Deleted]
[Deleted by Admins]
Old 06-05-2007, 05:52 PM
deserthonda's Avatar
you can also use the vacc from the pcv valve nipple , disconnect pcv hose from its source and use it ,,
Old 06-05-2007, 07:35 PM
I don't think Seafoam pulled through a vacuuum line will clean the EGR. The seafoam is pulled through the engine, combusted, and discharged into exhaust. It should clean the intake, pistons, and exhaust valves. A small amout of EG is recycled back through the EGR system to cool combustion. This EG will not contain much active SeaFoam, and seems unlikely to be an effective cleaner.
To clean EGR, I think you'll have to disassemble and mechanically clean. I've cleaned 3 systems now; two Accords and one Acura. All were filled w/ hard carbon that was difficult to remove even w/ direct access, chemicals (throttle body cleaner), and wire brush.
I have seen special purpose systems designed to clean EGR system w/ direct, pressure-energized injection of solvents directly though the EGR. It cost several hundred $ as I remember.
Old 06-05-2007, 10:01 PM
I did not see him asking to clean egr ports I tought he said carbon build up .....
AHHHHHHHH .. i just read the title
Old 06-06-2007, 06:53 PM
hondadude's Avatar
Lets hydrolock a motor class 101.
I'm in for the rod knock problem about to happen.....
Old 06-07-2007, 11:37 AM
I heard that Seafoam is not good for the motor has more than 150000 miles on them. Is it still true? I am just curious because I wanted to use that on my accord with 192000 miles on it and I am not sure if I can use it or not.I Have read this on other Honda forums.
Old 06-07-2007, 02:59 PM
inthedump's Avatar
accordfan222,
I saw on another site that the o2 sensor and/or spark plugs could get dirty from the first time application of seafoam. Not sure of the validity of that statement.
Quick Reply: How to use seafoam to clean egr
