Idle Surge after Brake Master Cylinder Install
Hi All.
I have a weird problem happening to me on my 1996 Accord EX Wagon.
I installed a new brake master cylinder because of a mushy brake pedal and it slowly moving toward the floor.
The pedal is nice and firm now but after a little bit of driving I came home and parked the car and put it in park and the idle started surging from around 900 - 1000 rpm up to about 1500 rpm and then after a second drops and then after another second heads back to 1500 and it keeps cycling like this.
Did I miss something? I think I can hear a hiss by the master cylinder but is it fuel or an air leak? I sprayed some soapy water in the area looking for bubbles and even felt with my fingers but nothing.
Any other clues?
Thanks.
Any other clues?
Thanks.
Hi All.
Any other clues?
Thanks.
Any other clues?
Thanks.
Either that or it has a leak. This is a big fat air hose located ontop of the brake booster. (the thing your master cylinder attaches to)
Trace all the vacume lines one by one in that area. Look for connections that are broken or cracked lines.
Genuine Honda MC seems to be good about the piston rod length (from what I've heard). People have said that aftermarket brands can have different length, & then you have to compensate by adjusting the pushrod from the pedal.
Check for double-gasket between the MC & the vacuum booster. I remember at least one thread where the old gasket stuck on the booster & he didn't notice (vacuum leak).
