If i clear SRS light
Old 10-06-2008, 02:38 PM
blackex19's Avatar
Default If i clear SRS light
If i follow the procedures to clear my SRS light will my airbags(or restraining system) actually work in an event of an accident?
Old 10-06-2008, 02:53 PM
finch13's Avatar
Default RE: If i clear SRS light
They should. Reset it and test it. JK!
But they should attempt to deploy no matter what.
Old 10-06-2008, 03:01 PM
blackex19's Avatar
lol its gonna be a pain in the butt trying to get that darn light to go off...
Old 10-06-2008, 03:14 PM
so cheat..............take the bulb out
Old 10-06-2008, 05:16 PM
what error code do you get ? (using the 2 pin connector under the glove box)
I have a 5-2 code and i couldn't get rid of the srs light yet, it seems i'm gonna need a new srs unit...
I hope you will be more lucky than me
Old 10-06-2008, 10:52 PM
blackex19's Avatar
how did you figure your error code? did you check it with a device? i may do so before attempting the fix
Old 10-07-2008, 03:23 AM
ORIGINAL: blackex19
Look under the glove box, on the right side, you should be able to find 2 blue connectors + 1 orange connector.
You will be using the smallest blue connector, which has 2 pins, do not use the other ones as you can damage your ecu or ABS...
Using a paper clip or small wire, short the blue 2 pin connector, then turn your ignition key to the II position (do not start the car)
Normally your srs light should come on for 6 seconds, then it will start to blink.
There should be some long blinks followed by short ones (example 4 long blinks followed by 3 short one means error 4-3)
It is important to know that each code will repeat three times and then move on to the next code.
You can get as much as 3 DTC codes.
SRS:
1-1 Open in the Driver’s Airbag Inflator
1-2 Increased Resistance in Driver’s Airbag Inflator
1-3 Short to Another Wire in Driver’s Airbag Inflator or Decreased Resistance
1-4 Short to Power in Driver’s Airbag Inflator
1-5 Short to Ground in Driver’s Airbag Inflator
2-1 Open in the Passenger’s Airbag Inflator
2-2 Increased Resistance in Passenger’s Airbag Inflator
2-3 Short to Another Wire in Passenger’s Airbag Inflator or Decreased Resistance
2-4 Short to Power in Passenger’s Airbag Inflator
2-5 Short to Ground in Passenger’s Airbag Inflator
3-1 Open in Driver’s Seat Belt Tensioner
3-2 Increased Resistance in Driver’s Seat Belt Tensioner
3-3 Short to Another Wire in Driver’s Seat Belt Tensioner or Decreased Resistance
3-4 Short to Power in Driver’s Seat Belt Tensioner
3-5 Short to Ground in Driver’s Seat Belt Tensioner
4-1 Open in Passenger’s Seat Belt Tensioner
4-2 Increased Resistance in Passenger’s Seat Belt Tensioner
4-3 Short to Another Wire in Passenger’s Seat Belt Tensioner or Decreased Resistance
4-4 Short to Power in Passenger’s Seat Belt Tensioner
4-5 Short to Ground in Passenger’s Seat Belt Tensioner
5-1 Internal Failure of the SRS unit
5-2 Internal Failure of the SRS unit
5-3 Internal Failure of the SRS unit
5-4 Internal Failure of the SRS unit
5-5 Internal Failure of the SRS unit
6-1 Internal Failure of the SRS unit
6-2 Internal Failure of the SRS unit
6-3 Internal Failure of the SRS unit
6-4 Internal Failure of the SRS unit
7-1 Internal Failure of the SRS unit
7-2 Internal Failure of the SRS unit
7-3 Internal Failure of the SRS unit
8-1 Internal Failure of the SRS unit
8-2 Internal Failure of the SRS unit
8-3 Internal Failure of the SRS unit
8-4 Internal Failure of the SRS unit
8-5 Internal Failure of the SRS unit
8-6 Internal Failure of the SRS unit
9-1 Faulty SRS Indicator Circuit or Faulty SRS Power Supply
9-2 Faulty SRS Power Supply
10-1 SRS Replacement Code
Good luck
Old 10-07-2008, 12:57 PM
blackex19's Avatar
too many wires, too many things in the way, can't do this.
1lowcaprice
02-09-2009 03:26 PM
Drpepper
09-24-2008 11:08 AM
62maxx
10-26-2006 01:04 PM
T07N
07-30-2006 01:40 AM
deserthonda
05-18-2006 05:24 AM
Quick Reply: If i clear SRS light
