Sponsored by:
Sponsored by:
2003 Accord code pulled
Old 06-26-2006, 02:28 PM
wonderllama
Default 2003 Accord code pulled
Last night the Service engine light came on while we were driving to a friends house. We actually needed gas, so I pretty much ruled out the gas cap, as it had been over a week since I had put in gas. So today we went to Autozone and pulled this code:
p0141
02 sensor heater circuit malfunction
bank 1
sensor 2
Can anybody give me more information on this?
Old 06-26-2006, 03:33 PM
YeuEmMaiMai's Avatar
Default RE: 2003 Accord code pulled
what it means that that the heater inside the O2 sensor has failed or the wiring to the circuit is bad
Old 06-26-2006, 09:17 PM
Chiovnidca's Avatar
ORIGINAL: wonderllama
p0141
bank 1
sensor 2
A good test to verify the problem is to check the resistance of the o2 heater. Should be 10-40 ohms. That's on the 2ndary sensor, the one in the cat.
Old 06-27-2006, 12:26 AM
taffgorman
I had this filure on my 2003 Accord at about 30,000 miles. It will have to be replaced. Honda quality might be good but the quality of their parts suppliers seems spotty.
Old 10-11-2006, 08:59 PM
drachen
I got this same code (P0141) on my 96 Accord. Do you know what the fix is and about how much? Thanks
Old 10-11-2006, 09:55 PM
Sort of the same story for your car. The secondary O2 sensor is the rear one, in the cat or towards the rear of the cat.
Measure resistance between the 2 same-color wires of the O2 sensor. Should be 10 to 40 ohms; if not, get a new sensor.
If that resistance is OK, then you have to start looking for wiring problems in that circuit.
Old 10-11-2006, 10:04 PM
deserthonda's Avatar
if car has 36k miles or less it is totally under warranty.also being an emission related part it might be coverd longer than 36k,
call your local dealer and ask what the warranty is
Custnam
04-15-2013 10:30 PM
accords own
09-06-2007 06:26 PM
CoryTheStory
06-20-2007 12:54 AM
HondaLawgik
03-03-2006 07:08 PM
biglarge
11-27-2005 03:21 AM
Quick Reply: 2003 Accord code pulled
