ignition coil: no primary winding resistance
Old 09-19-2006, 04:46 AM
deserthonda's Avatar
Default RE: ignition coil: no primary winding resistance
chk the TW sensor ..
Old 09-19-2006, 02:43 PM
klyphman's Avatar
TW sensor is reading proper resistance when cool, but could it malfunction when it is hot?
Could a faulty O2 sensor cause this problem??
Old 09-19-2006, 09:45 PM
it could.....when it wont start, pull the plugs out and see if they look like gas flouled ,,,,,,
.chk engine lite on?? you should chk for codes
Old 10-06-2006, 11:09 AM
klyphman's Avatar
Been out of town lately. Here is update: A mehanic had no clue about the problem, but we did ascertain that in the no start condition, the engine is flooded, but would still cough to life briefly when the fuse for the alternator/fuel pump was pulled. When the fuse was reinserted, the engine instantly died.
Also, last night, the check engine light came on reading a code 6 for tw sensor. I will replace it and see if this causes the problem. Likely culprit?
Old 10-11-2006, 08:53 PM
klyphman's Avatar
It was the TW sensor. Replaced it and reuns perfectly.
Thanks for the tips.
Old 10-12-2006, 04:43 AM
ORIGINAL: klyphman
from the symptoms you described i had a feeling it was the TW sensor........Glad that it is fixed
Agate
07-20-2015 10:59 AM
phantomgrey92
10-09-2013 04:45 PM
Pat61
04-20-2012 03:21 PM
57 T-Bird
04-28-2010 11:50 AM
mtex5spd
11-22-2004 03:47 PM
Quick Reply: ignition coil: no primary winding resistance
