Clutch Pedal - No Pressure
I have a 2000 Honda Accord and a new clutch was put in the car not by me by my father-in-law and a new master cylinder have problem shifting it pretty much since day one and I can't get a straight answer if the flywheel was turned or not I've recently replaced the slave cylinder, but I have no pressure on the pedal whatsoever I've bled the clutch line I don't know if I'm doing it right, this is the first time I've had a Honda, recently my Monte Carlo of (18) years decided to just catch on fire in the driveway. Any help would be greatly appreciated, as I said, I really don't know what I am doing. The pedal just flops pretty much there's there's no pressure whatsoever it's got a new master cylinder new slave cylinder new clutch
Yes, it was working great, the car sat for a little over (3) years, on a slab of concrete, no cover.
Most likely you have air in the line. You need to bench bleed the master cylinder before installing, or you can have air trapped in there.
Your new master or slave cylinder could be bad out of the box. You can try installing the old master or slave to see if your pedal works.
There are some good ericthecarguy videos on youtube on how to replace the clutch master cylinder to show you how to install this on a Honda.
