Sponsored by:
Sponsored by:
keyless entry reprogramming
Old 05-07-2012, 09:32 PM
rdahabreh's Avatar
Exclamation keyless entry reprogramming
Hi,
Honda Accord 2007.
I lost my keyless entry key to my accord, I need way to either disable keyless entry at all or reprogram my other key with new code so the old old one doesnt open my car anymore.
I am concerend if someone walks around the street and keeps clicking the car keys till he finds my car..
Rami
Old 05-07-2012, 09:54 PM
Got this from another site. It matches the shop manual.
2003-04 Accord LX and EX with factory-installed keyless entry system
Programming the Transmitter
NOTES :
^ The system accepts up to three transmitters. The transmitter codes are stored in a stacking-type memory. If a fourth transmitter code is programmed, the code for the first transmitter is erased.
^ Entering the programming mode cancels all learned transmitter codes, so none of the previously programmed transmitters will work. You must reprogram all of the transmitters once you are in the programming mode.
^ You must complete steps 1-6 within 4 seconds of the previous step to keep the system from exiting the programming mode.
1. Turn the ignition switch to ON (II).
2. Press the "Lock" or "Unlock" button on one of the transmitters. (An unprogrammed transmitter can be used for this step.)
3. Turn the ignition switch to LOCK (0).
4. Repeat steps 1 2, and 3 two more times using the same transmitter used in step 2.
5. Turn the ignition switch to ON (II).
6. Press the "Lock" or "Unlock" button on the same transmitter. Make sure the power door locks cycle to confirm that the system is in programming mode.
7. Within 10 seconds, press the "Lock" or "Unlock" button on each transmitter. Make sure the power door locks cycle after you press each transmitter button to confirm that the system accepted the transmitter's code.
8. Turn the ignition switch to LOCK (0) to exit the programming mode.
fadhelbh
06-15-2013 07:07 AM
AccordCoupe2006
03-04-2006 05:40 PM
IUHooshur
01-04-2006 12:04 PM
sastone75
11-18-2005 08:38 PM
93Miata
11-10-2005 08:06 AM
Quick Reply: keyless entry reprogramming
