location
location
i need to replace a knock senor on a 2001 honda accord lx 4 cyl 2.3.. i cannot find where i it is located,. does anyone know where it is? or have a diagram so i can see where it is. i tried to google it but couldnt find it.
The knock sensor is #14 in the picture. On the back side of the engine block, under the intake manifold. Probably easier to see from below the car.
#15 is the oil pressure switch - that one has 1 wire. The knock sensor has a plastic plug with 2 wires, similar to the fan switch in the T-stat housing.
Here is a photo of the location of the knock sensor, it is above the oil filter on the left side.
Both the knock sensor and oil pressure switch have one wire connectors.
