Main relay signs/symptoms?
Old 06-24-2006, 06:44 PM
jrcastro's Avatar
Default Main relay signs/symptoms?
What are the signs & symptoms of the main relay issue on a 92 accords?
I start my car gas & fuel get in fine then all of the sudded it dies, try it again then it will not start.
What else could it be?
I wait a few minutes it works fine. this only happens occasionaly.
Old 06-24-2006, 06:59 PM
Chiovnidca's Avatar
Default RE: Main relay signs/symptoms?
ORIGINAL: jrcastro
Sounds like it. they usually act up more when it is hot out. Checking it for cracked solder joints is a good diagnostic procedure.
Old 06-24-2006, 08:03 PM
mbo1985's Avatar
yeah, sounds like the main relay could be giving you a problem. As Chiovnidca said, look for cracked or dull looking solder joints if you decide to check it out.
Old 06-24-2006, 11:28 PM
deserthonda's Avatar
if you go to the DIY section, there is a link to a write up on main relay
Old 06-26-2006, 01:20 PM
jrcastro's Avatar
When driving the car all of a sudden it died (only happened once) tried to restart no luck. waited a few minutes started fine.
Is this also one of the signs/symptoms?
I thought the relay problems are only upon start up?
Could it be something else?
NOTE: Probable main relay problems started acting up on a normal 85degree day in Ca. is this hot enough to make the relay malfunction?
Old 06-26-2006, 09:20 PM
Chiovnidca's Avatar
ORIGINAL: jrcastro
A main relay very rarely causes a stalling problem like that. Next ime it happens, see if it has spark.
mamtsberg
05-27-2013 01:55 PM
HondaPete14
02-15-2012 05:34 PM
greg05
08-31-2009 05:32 PM
jrcastro
04-21-2008 10:35 AM
HondaAccordNewb
01-16-2008 06:08 PM
Quick Reply: Main relay signs/symptoms?
