Sponsored by:
Sponsored by:
Maintenance Schedule
Old 02-09-2012, 08:14 PM
tobybul's Avatar
Default Engine Oil Life Indicator
What does it mean if the indicator stays at 100 all the time? Can it be programmed any other way like changed when it gets to a certain mileage rather than sense oil life?
Thanks.
Old 02-10-2012, 06:58 AM
Can't be reprogrammed as far as I know. I doesn't count down 99%-98% etc. I only goes by 10% steps, so it won't change until suddenly it shows 90%.
Old 02-10-2012, 07:46 PM
EXV6NIGHTHAWK's Avatar
The "maintenance minder" operates by monitoring the engine (rpm, ect), and calculates oil life that way. There is no set mileage/time interval. I have an 03 Accord, and they didn't have the "Maint. Minder". If you want to go by mileage/time intervals (the old way), you could use the maintenance intervals for an 03 Accord. It's the same engine, same car.
Old 02-10-2012, 08:45 PM
Try resetting the maintenance minder, press for 10 seconds till it blinks, then press another 5 seconds. Then check after you driven for 2-3 weeks to see if it changes. If not, you may have to go to the dealer to let them use HDS (Honda Diagnostic System) to try to reset it.
Old 02-13-2012, 06:48 AM
You can't reset it until it gets down to 15%. How long (miles) has it been at 100%? I bet it's working & you simply have to wait a little bit until it displays 90%. It will not display 99%, 98%, etc.
Old 03-25-2012, 03:17 PM
tobybul's Avatar
Aftere resetting the maintenance minder and changing oil, the percentage indicator now works as expected. I've logged over 1000 miles and its now dropped to 90%. The PO must have just reset it b4 I bought the car.
  #17
Old 10-02-2012, 03:20 PM
does anyone know if ther is a PDF of the maint grid?
thanks! first post!
  #18
Old 10-02-2012, 04:51 PM
thanks! first post!
It's in the owner's manual. Your 2006 has the Maintenance Minder. See attached pic. for maintenance minder symbols and items.
tzoromski1
10-06-2012 12:05 AM
samtycun
11-24-2011 05:55 PM
JAYNESS the Great
10-16-2011 08:23 AM
Bob Guercio
09-10-2009 06:55 AM
Ronin_301
07-08-2006 02:24 PM
Quick Reply: Maintenance Schedule
