Maintenance schedule
RE: Maintenance schedule
Here's a list from our own Master Tech (Desert Honda) that seems to be a great one to follow.
oil and filter every 3000 miles,,,,,if u reside in a cold winter climate use 5-20 oil if warm climate use 10-30.... if it is a manual tranny replace fluid ever 30k if it is AT every 15k, use honda atf z1,,,,cabin filter once a year ,, brake fluid flush every 30k , air filter every 15k if u reside in a dusty climate do sooner ..rotate tires every 7500 miles ,,i believe u got platinum plugs ,, replace those every 60k,,, use NGK plugs only.....
Skip the cabin filter of course.... Replace your timing belt every 70-80,000 miles and your waterpump at the same time....
