Need help with A/C.. Is this problem a easy fix?
Old 09-16-2009, 09:42 PM
prodigy215
Exclamation Need help with A/C.. Is this problem a easy fix? Need help asap.
Hey there guys im new to the Honda world, first time owner. I have a 93' Honda Accord. The A/C never worked since I had this car. My car defroster, or heat does not work either. When I hit the button to turn on A/C, Heat, or Defrost. The light turns on to indicate that it is on, and nothing blows out the vent.
What could the problem be? Reply asap. thanks
Old 09-16-2009, 11:44 PM
I would start by checking for a blown fuse. My 95 has a 7.5 amp fuse in the interior fuse box that protects those circuits, but yours is likely in a different location. You can download a 91 shop manual from the online manuals thread in the diy section. It will help you to identify the fuse in your car that protects the heater controls.
Old 09-17-2009, 08:11 AM
prodigy215
Exclamation
I just checked the interior fuse box and the fuse box under the hood. All the fuses in the car are good, none are blown. What would your next solution or suggestion be? Reply asap. thanks
Old 09-20-2009, 11:52 AM
hondadude's Avatar
So the customer complaint is no heater blower motor?
Caveman test.
Turn the key on and blower motor to high, reach up under the glve box and thump the bottom of the blower housing to see if the fan motor jogs on.
If this works, the blower motor brushes are worn out and you'll need to replace the blower motor.
Power should be available at the Yellow/black wire at the blower motor connector, power comes from underhood fuse #18-30amp
theteri
04-22-2014 08:38 AM
EXV6NIGHTHAWK
10-08-2012 08:00 PM
Gtwo305
02-10-2011 08:06 PM
90 accord lx
06-02-2007 07:52 PM
mrstangblb
12-24-2005 12:52 PM
Quick Reply: Need help with A/C.. Is this problem a easy fix?
