Sponsored by:
Sponsored by:
Need help with my 91 Accord lx
Old 10-20-2014, 10:12 PM
Tiny Meek's Avatar
Default Need help with my 91 Accord lx
Bought a new battery, starter, distributor cap & rotor, and the ignition coil but my car still won't start. It's turning over but not starting. Help!! Lol
Old 10-21-2014, 05:33 AM
Turtlehead's Avatar
Bad ignitor? Assuming you have fuel delivery it is a likely and common part to fail on older high mileage vehicles.
Old 10-21-2014, 08:48 AM
Tiny Meek's Avatar
Once started the car is fine. Getting it started it's my problem. When I jump it, it starts right up.
I'm definitely going to be looking into the ignitor tho.
Old 10-21-2014, 10:18 AM
First step in fixing a no-start is determining whether fuel or ignition is causing no-start.
Suggest attempting to start w/ a long (5-10 sec) blast of throttle body cleaner or starter fluid in the air intake duct. Attempt to start.
If no-start continues, the ignition problem is highly likely; ignition switch assy, ignitor, coil are things to inspect.
If engine starts and runs briefly, then fuel delivery problem is causing no-start. This is usually Main Fuel Relay fault, or less likely sticking fuel pump.
Old 10-23-2014, 09:02 PM
Tiny Meek's Avatar
Thank you so much Texas Honda
Definitely trying that in the morning
99accordf23a5
05-06-2014 12:51 AM
brandyn
11-26-2013 05:31 PM
mamtsberg
03-17-2010 09:15 PM
90accord90
01-16-2010 06:01 PM
Quick Reply: Need help with my 91 Accord lx
