Need help putting accord alternator on drag car
Old 11-24-2015, 10:51 PM
hitecmal's Avatar
Default Need help putting accord alternator on drag car
hy to one and all I have a small block mopar drag car and a 2003 accord alternator that matches up to my brackets almost perfect. the problem I don't know which pin outs will get it charging. its a 4 pin unit what for it to do charge. thx.
File Type: doc
Old 11-25-2015, 09:34 AM
travrach's Avatar
Old 11-25-2015, 11:58 AM
hitecmal's Avatar
thx for the quick reply perhaps you can explain a bit more
1. it is my understanding wire one goes to a fused ign on wire
2. the white green wire goes to a 12 volt source the excites the alternator to charge.
however i'm not sure I need 3 and 4 but if i do explain what is meant by altl and fr signal altf.
this is going in a 1987 dodge dakota which use a pos field wire and a field to ground wire.
so if i'm going to install this correctly i'm going need to what the abbreviations stand for. also if i gotten the wrong definition of plugs 1 and 2 wrong pls correct me thx.
Russianred
03-05-2012 01:40 AM
Mexjames
03-11-2009 05:23 PM
88AccordLX3152
11-06-2008 11:00 AM
ieetgluu
14
09-16-2008 10:57 PM
Quick Reply: Need help putting accord alternator on drag car
