noise when turning steering wheel - Honda Accord Forum - Honda Accord Enthusiast Forums
Reply
Thread Tools Search this Thread
Old 12-11-2007, 11:56 AM
Default noise when turning steering wheel
ok whats wrong with my car
when the car is ON and i turn the steering wheel it feels really hard and it makes noise like grinding
but when i turn the car off and turn the wheel it turns fine with no noise so wtf ?
Old 12-11-2007, 12:22 PM
jj02accordv6
Default RE: noise when turning steering wheel
Does it happen all the time or udner certain condition? i.e. after rain, cold days, etc.
Old 12-11-2007, 01:07 PM
SOunds like a problem with your power steering. Have you checked the fluid level?? Any leakage??
Old 12-11-2007, 02:47 PM
finch13's Avatar
What about belt tension on the power steering pump. Any squealing?
Old 12-11-2007, 07:27 PM
i dont know the car been pared for a month and before that i rememver hearing it just for 2seconds a day now i turned the car on after a month and it would stop and its crazy loud ill take a video next time sounds like metal on metal... someone told me iots the balljoint but when the car is off i can turn it just fine so it cant be the ball joint so i thas to be the power steerring pump but how do i find out for sure because there is fluid in there and i can see the fluid moving around in there so i have no idea
Old 12-11-2007, 07:39 PM
finch13's Avatar
Well belt squeal sounds like nails on a chalkboard or metal on metal. Sounds like maybe the belt might have enough slack or is worn enough to squeal when the pump is running.
Old 12-11-2007, 08:00 PM
so, it's really hard to turn the wheel with the car running, but when you shut the car off it's EASY to turn the wheel? [:-]
Reply
Thread Thread Starter Forum Replies Last Post
Turning Steering wheel hard at first when it's cold? b8man General Tech Help 1 12-12-2013 10:22 AM
steering wheel squeak when turning slowly d0n General Tech Help 6 08-26-2013 01:15 PM
squeak when turning steering wheel 1999EX General Tech Help 4 03-29-2013 03:22 PM
brake light on dash appears when turning key to start or turning over huhdo General Tech Help 1 08-30-2012 09:06 PM
which is a better security? no steering wheel or a steering wheel club? thunder_x Off Topic 28 08-11-2007 10:31 PM
Tags
2000, accord, car, clunks, hard, honda, makes, metallic, noise, steering, sterring, stoped, turn, turning, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
