Sponsored by:
Sponsored by:
noise when turning steering wheel
Old 12-11-2007, 11:56 AM
mrscotty's Avatar
Default noise when turning steering wheel
ok whats wrong with my car
when the car is ON and i turn the steering wheel it feels really hard and it makes noise like grinding
but when i turn the car off and turn the wheel it turns fine with no noise so wtf ?
Old 12-11-2007, 12:22 PM
jj02accordv6
Default RE: noise when turning steering wheel
Does it happen all the time or udner certain condition? i.e. after rain, cold days, etc.
Old 12-11-2007, 01:07 PM
falkore24's Avatar
SOunds like a problem with your power steering. Have you checked the fluid level?? Any leakage??
Old 12-11-2007, 02:47 PM
finch13's Avatar
What about belt tension on the power steering pump. Any squealing?
Old 12-11-2007, 07:27 PM
mrscotty's Avatar
i dont know the car been pared for a month and before that i rememver hearing it just for 2seconds a day now i turned the car on after a month and it would stop and its crazy loud ill take a video next time sounds like metal on metal... someone told me iots the balljoint but when the car is off i can turn it just fine so it cant be the ball joint so i thas to be the power steerring pump but how do i find out for sure because there is fluid in there and i can see the fluid moving around in there so i have no idea
Old 12-11-2007, 07:39 PM
finch13's Avatar
Well belt squeal sounds like nails on a chalkboard or metal on metal. Sounds like maybe the belt might have enough slack or is worn enough to squeal when the pump is running.
Old 12-11-2007, 08:00 PM
so, it's really hard to turn the wheel with the car running, but when you shut the car off it's EASY to turn the wheel? [:-]
b8man
01-02-2018 09:25 AM
d0n
08-26-2013 01:15 PM
1999EX
03-29-2013 03:22 PM
huhdo
08-30-2012 09:06 PM
Quick Reply: noise when turning steering wheel
