93 Accord (obd2) code 9 reading
Old Mar 12, 2011 | 05:13 PM
dumbtrumm's Avatar
Default 93 Accord (obd2) code 9 reading
my check engine light came on, so i tested it and got a code 9. i bought a new distributor and replaced it, and it seems to be running smoother, but i am still getting a code 9 on my check engine light. does anyone have any tips or ideas as to what could be wrong? thank you.
Old Mar 12, 2011 | 05:17 PM
dumbtrumm's Avatar
i meant to say obd1. sorry.
Old Mar 12, 2011 | 05:56 PM
I had very much the same experience, Code 9, replaced distributor and code 9 remained. If you read the diagnostics for this code, you check the resistance of the distirbutor sensor.
If you check the resistance and it's acceptable (350-700 ohms for B1 and 700-1300 ohms for B2), then a further check is indicated from the ECU connector under dash behind passenger's foot carpet. You will need a shop manual to get the right connector and wire color.
If resistance checks OK at the ECU, then a new ECU is likely necessary. Check car-part.com for a used unit near your zip code.
This is what I found and had to replace ECU to fix.
kingofudupi
Dec 28, 2021 03:31 PM
Kludge
Feb 19, 2013 10:03 PM
bastian
May 9, 2010 04:47 PM
Bacondoggy
Oct 5, 2009 10:27 PM
yoshi16
Oct 23, 2008 02:24 PM
