Oil Dipstick Leak
Old 03-20-2012, 08:50 PM
Jamar.stroud's Avatar
Default Oil Dipstick Leak
Hello all! I am new to this forum and am thoroughly enjoying it so far!
I own an '08 Accord and am having an issue with a leak from where the oil dipstick goes into the engine. I have noticed small oil spots on the floor in the garage.....well after opening the hood to check the oil level, I noticed that there was a trail of gunked up oil leading from where the stick goes into the engine on down the engine to the floor. I cleaned it all up as best as could, but am wondering is anyone else having this problem and if so whats the fix.
I also noticed that there are two small rubber gaskets at the top end of the dip stick. Could it be that all I need to do is replace those gaskets? Any thoughts/help/advice is certainly welcome! Thanks!
Old 03-21-2012, 10:13 AM
If those o-rings are not sealing off then that could be the source. Didn't see the o-rings listed by themselves, the "stick" was listed for ~$10 online.
Old 03-21-2012, 01:44 PM
Thanks! Yeah, I just went ahead and ordered a new dipstick from Honda for $7. Hopefully this will be the end to this problem.
Old 03-24-2012, 02:02 PM
Just put in my new oil dipstick. I can definitely tell a difference between the new one with the new "O-Rings" as opposed to the old one with worn out "O-Rings." The new one actually has to be slightly forced in where as the old one slid in with little resistance. Problem Solved!
macmini05
10-20-2011 01:33 AM
myfirstisanaccord
05-13-2011 03:07 PM
miki
08-06-2006 06:04 PM
newaccord99
07-16-2006 08:15 PM
joshuaaaronalpert
05-29-2005 11:42 PM
Quick Reply: Oil Dipstick Leak
