Oil Pressure / Oil Temperature / Water Temperature
Hi! There ...
I bought a aftermarket 4-in-1 Tachnometer with all senders (sensors) included
I have an 1990 Honda Accord 4-Door EX, Manual Transmission
However, I ran into some problems installing the sensors, or trying to tap into the right wires to get the readings ....
For Water Temperature, I tried the sensors underneath the distributor cap, it gave me a reading, but the problem was...the engine won't start, only the reading comes when the tapped-connection is done after the engine is already started
As for the Oil Temperature and Oil Pressure, I have no idea where those ares ...
I asked my mechanic, he is unable to provide to ideas of where to install these senders
We also tried tapping the sensor wire (assuming it was for Oil Pressure) on top of underneath the Oil Filter area, again, no luck
Herewith, I am attaching a eBay link to the product I got, just for reference, but if you need images of the actual sensors (senders), I don't mind attaching them later on, but you can see a small image of the actual sensors on the eBay link
Also, since I got this used car for $1000.00, the engine actually says F20A,not H22A ... like 2.2 it should be ...
So, can someone please tell me where to tap to (the wire colours,) or the sender installation locations for Oil Temperature , Oil Pressure and Oil Temperature
Thanks!
The link is below:
http://cgi.ebay.com/New-4-in-1-Tacho...ayphotohosting
Thanks!
The link is below:
JimBlake
02-19-2020 03:05 AM
Jimmy Bringus
06-14-2015 04:55 PM
eduard
05-09-2013 12:11 AM
piconrule
07-24-2009 02:38 PM
