One Headlight out in 1999 Sedan, replaced bulb still not working, help!
Hello, I have a 1999 v6 sedan.
Last week the driver's side headlight went out. I bought a new bulb (yes, the correct one) but it still won't come on. The highbeams work on both sides and the passenger headlight normal beam works fine.
I figured it might be a fuse, but usually both would go out. I pulled the fuse panel door by the driver's door and there is no fuse for the headlights. Am I missing something?
The plug and all wires leading to the driver's side headlamp appear to be in good shape and nothing noticble is loose or corroded.
I have to take the car in for an oil change this week anyway, but don't feel like paying my mechanic a bunch of money to diagnose or troubleshoot this if it is something simple.
Thanks.
Thanks.
I checked the box in the engine bay and both 20A healight fuses are fine.
This is killing me because I got a ticket for one headlight the other evening. My mechanic said it might be a "wiring problem", which means I will have to pay him a lot of money to track it down.
Is there something I am missing? Anyone else ever have a headlight out and neither fuse nor bulb are bad? This is an EX V6 by the way. Thanks.
You will need a volt meter to do some testing. I would start at the electrical connector for the headlight that is not working. Unplug that connector. Turn on the headlights. Put the red meter lead on the non-black pin of the electrical connector. Put the black meter lead on the valve cover. See if you have have about 12V.
Let us know what you find.
zann121
12-17-2009 11:05 PM
