In and out of OVERDRIVE on a '93
Old 07-22-2008, 09:07 AM
MikeT's Avatar
Default In and out of OVERDRIVE on a '93
My '93 4-cyl LX has been quickly going in and out of overdrive (D4) at hwy speed. Is there a sensor to replace or something that needs to get cleaned out?
Old 07-22-2008, 09:12 AM
MikeT's Avatar
Default RE: In and out of OVERDRIVE on a '93
I say "overdrive" it might be the lockup torque converter....
Old 07-22-2008, 09:43 AM
Maybe adjustment of the downshift cable, from throttlebody down to tranny?
Old 07-22-2008, 11:30 AM
MikeT's Avatar
I just spoke to a Hon Mech and he said the O2 sensor might be leaning out the mix. Lean surge?
Old 07-22-2008, 12:41 PM
drummer1279's Avatar
Mine had the same issue. turned out it was a combination of the transmission fluid and the temperature sensor going bad. I did the customary fill-drain 3 timer and replaced the sensor and now it stays in overdrive.
Old 07-23-2008, 03:51 AM
YeuEmMaiMai's Avatar
replace your t-stat
Old 07-23-2008, 06:35 AM
MikeT's Avatar
Where is the temp sensor located?
Old 07-25-2008, 04:37 PM
Hondaccord's Avatar
I agree with the suggestion to replace your thermostat. A very small drop in engine temp may prevent the tranny torque converter from locking up.
Old 07-25-2008, 07:18 PM
hondadude's Avatar
It's normal to go in and out of lock up at hwy speeds. I'd explain further but then I'll get a "404" error
Old 07-26-2008, 08:47 AM
Is the D4 light blinking? If yes, get the TCU code and post back. This will provide guidance on fault.
Quick Reply: In and out of OVERDRIVE on a '93
