P0401
Old 07-30-2014, 01:39 AM
98EXV6's Avatar
Default P0401
Got this code on my son's 02 V6 coupe after the ECL and TCS lights lit up. Went ahead and looked it up code is clogged or insufficient flow on the EGR. Removed the intake manifold and cleaned the heck out of it with throttle body cleaner. Sorry forgot to post pictures but it's very easy.
Old 07-31-2014, 06:59 AM
Turtlehead's Avatar
FYI - there is a fix for the EGR clogging problem on your V6. The EGR port on the intake is honed out with a special bit and a stainless steel tube is then inserted. There is a special kit available for this job.
Old 08-01-2014, 04:12 AM
98EXV6's Avatar
yup I've read about that but you have to drill to open the hole a little bit for the stainless tube to fit
Old 08-02-2014, 09:21 AM
Yea, a co-worker had the same issue.
He didn't use the "kit" either - BTW Dorman Products sells the kit also. He pulled the intake and cleaned it, I think he used a "pipe cleaner" brush as well. Put it all back together and has been driving issue free for several months.
Old 08-05-2014, 09:00 AM
I'm a bit curious how this works out. Just to compare with or without the kit, how long it lasts before it gets clogged up again.
In my real life I've had to deal with a situation where certain temperatures & pressure promote coking of a carbon-rich gas. And certain metals are good catalysts to promote the coking to happen even faster. So maybe that "stainless" tube is made of a particular metal that slows down the process.
Dale269
09-22-2011 10:49 AM
99lx
12-27-2008 06:26 PM
Tippman7641
11-05-2008 01:21 PM
whitgrl
07-15-2007 11:08 PM
sali1976
03-29-2007 11:07 PM
Quick Reply: P0401
