p1362, p1382 no sart condition HELP
Old 02-16-2011, 11:55 AM
falon871's Avatar
Default p1362, p1382 no sart condition HELP
i have a 98 accord 2.3 ex. died while driving. will no restart. scanner shows p1362 no signal, p1382 no signal. also the security key light was flashing when engine was dying.
Have good fuel pressure, replaced the TDC, crank sensors, and replaced the distributor, timing belts while in there. good compression. still no start, no spark.. all connections are clean corrosion free all the way to the ecm. ANY IDEAS THAT I MIGHT HAVE MISSED.
I also cleared the codes, and while crankiing the engine the same codes reappeared. still no spark. I thought the key code might have been an issue, but since there is good fuel pressure, thats out.
JOe
Old 02-16-2011, 02:32 PM
I would check fuses protecting the PCM.
Did you measure the resistance for each sensor connector on the sensor electrical connector? Does that resistance match the resistance at across the proper pins at the ECU?
Old 02-16-2011, 07:03 PM
falon871's Avatar
yes, readings are exacly the same. i checked all three inputs, from the crank and the distributor.
Old 02-16-2011, 07:08 PM
At the PCM connector, check to see if any of those pins that you checked are closed to ground (grounded wire check).
Old 02-17-2011, 10:31 AM
falon871's Avatar
I unplugged bith ends of the harness, and did an ohm reading. got no shorts, and then checked for opens , it was good. ill recheck fuses again
Old 02-17-2011, 10:03 PM
falon871's Avatar
everythings checks out good. im leaning toward a fried ecm.
Old 02-17-2011, 10:11 PM
I am not so familiar with the 6th gen accords. Does the key immobilizer cut off fuel pump or just the fuel injectors? Does it also cut off spark?
It can't hurt to try another key, if the transponder in your original key is messed up.
The PCM is usually the last item that you would suspect to be the problem. If you decide to get a PCM, you will have to program the key(s) for a that new PCM.
Old 02-18-2011, 09:57 AM
falon871's Avatar
I was looking at the wiring diagrams, and the only circuit i see for the immobilizer if for the fuel pump. I did try all three keys. and we do have fuel pump operation and good pressure. just no spark. Of coarse there may be a possibility that not all circuits were included in the diagrams. is there a way to bypass the immobilzer to test this circuit?
Old 02-18-2011, 10:15 AM
The spark is controlled through the ECU and the immobilizer circuit is also in the ECU. So it's possible it cuts out spark without any external circuits.
Old 02-18-2011, 11:11 AM
falon871's Avatar
Its a possibilty. The immobilzer key light on the instruments panel was flashing on at the time the engine was choking out, (light on engine dead, light off engine continued to run). it did this about 3 times before it stopped running, and i had to pull over. hasnt run since. but the light operates normally now.
Quick Reply: p1362, p1382 no sart condition HELP
