Sponsored by:
Sponsored by:
Periodically engine just dies while driving. Tough to restart, seems fuel starved
Old 02-11-2017, 05:31 PM
Stonacek's Avatar
Default Periodically engine just dies while driving. Tough to restart, seems fuel starved
When I start my '99 Accord the Maint. required light blinks 3 or 4 times. Engine starts just fine, drives normal, no rough idle, nothing noticeable. The other day, was sitting at a stop light & the engine simply stopped, little to no fuel pressure (fuel pump?) bc the starter just turned & turned, wouldn't start, had to apply accelerator, hard several times, pumping pedal hard to get fuel, finally started & ran just fine, again, no problems for approximately 25+ miles, maybe more, then as I was pulling out of a parking lot into moving traffic, again, same thing, motor just didn't have fuel & would not start by key or by dropping clutch in 2nd/3rd gear (manual trans), nothing until I pump the accelerator several times. Once the car starts it runs perfectly normal.
I'm thinking it's a fuel pump issue? why else would I have to step into the accelerator so many times to get the thing to fire. Can't be ignitor/coil as I would simply be dead, no spark, no fire?
Anyone ever have this happen to them? Couldn't find a similar thread for this era of Accord 2.3ltr 4cyl, manual trans '99 Accord EX
Old 02-11-2017, 05:59 PM
Had to "call" this a fuel issue only.
Being a 99 4 cyl I have to ask if the normal maint items of the ign system are up to date - plugs, cap, rotor, inspect/test wires?
Yes the fuel pump relay (main relay) can go "flaky" but so can a few other systems (ign and ign switch). Fair;y simple to tap into the power wire to the fuel pump and add a "light" that is on when power is going to the pump.....then what does the light do when the car acts up
heronbassett
08-14-2014 10:14 PM
tgulley
07-29-2013 05:28 PM
Dis_ill_usions
09-05-2012 11:24 PM
1995capricewagon
12-01-2007 03:56 PM
dragoneyes
10-29-2007 02:47 PM
Quick Reply: Periodically engine just dies while driving. Tough to restart, seems fuel starved
