Radiator fans
Old 08-28-2008, 07:12 PM
kornbln
Default Radiator fans
I just replaced the radiator on a 97 Accord (had a leak). Instructions I found online said to put the coolant in, turn on the engine and let it run until the radiator fan comes on twice. I let the car run for a while and it never came on. So I took it for a drive and everything seemed to be running good. No leaks, good temperature. The A/C fan comes on when I turn the A/C on (standing in front of the hood, the one to the left next to the overflow reservoir), so I know that one is working...But the same fan comes on automatically after I park the car. Shouldn't it be the other fan coming on?
Old 08-29-2008, 01:15 AM
Default RE: Radiator fans
The driver's side fan is technically called the a/c fan, and the passenger side fan is the radiator fan. I know that both should turn on when the a/c is on.
Old 08-29-2008, 01:18 AM
kornbln
PAhonda,
Yeah I just read that both should be running when the A/C is one. They aren't. What should I check?
Old 08-30-2008, 08:07 AM
cabinhill
Check the fuse for the radiator fan. If its good check for voltage on the connector to the fan.
Old 08-30-2008, 02:16 PM
Either the fan isn't getting power or the fan is shot. The quickest way to determine the problem is
Unplug connector to non-working fan, turn on car and a/c. Stick a volt meter on the two leads.
If you have 12V, replace fan. Iif you smack to motor with the handle of a screwdriver and the fan turns on, the fan motor is definitely shot.
If no voltage, then something electrical is the problem upstream.
pab59y
09-13-2011 06:33 PM
bmo21
08-02-2011 09:03 PM
drummer1279
03-29-2011 02:59 PM
88LXI
09-27-2009 04:54 PM
horgad
12-10-2006 07:57 PM
Quick Reply: Radiator fans
