Poor acceleration
Old 11-07-2009, 09:48 AM
Maverx's Avatar
Default Poor acceleration
I just got a 1993 Honda Accord EX and it has poor acceleration until i get to 2500 rpm and then it is fine. Any ideas?
Old 11-09-2009, 07:18 AM
Is it smooth & underpowered? Or does it sputter & shake?
If smooth...
Mis-adjusted tranny cable (the cable that goes from throttle down to the tranny)?
If not smooth...
How old are the spark plugs? Distributor cap & rotor? Tune-up stuff like that?
Old 11-09-2009, 09:47 AM
Maverx's Avatar
It is Smooth all the way. I have not heard about the tranny cable ill have to look into that, thanks.
I was also going to check the Cat convt to see if it isnt clogged, could this also be it you think?
Could it have anything to do with the EGR valve or fuel system?
Old 11-09-2009, 09:52 AM
I haven't had these conditions firsthand, but here goes...
Clogged cat SHOULD(?) restrict more at higher RPM & higher load. That's when the exhaust flow rate is highest.
People usually describe EGR problems as stumbling - not smooth.
Old 11-09-2009, 09:23 PM
Maverx's Avatar
The throttle control cable that goes to the tranny is working properly and is in sync with the throttle.
Even if i rev the car up in nuetral it bogs until it gets to 2500 rpm then its like it hits a power band and shoots up just fine.
Could it be a dirty fuel delivery .. like the throttle body or fuel rail?
Old 11-15-2009, 03:34 PM
Maverx's Avatar
Replaced the spark plugs, cap, and rotor, still the same acceleration problem but it does run a little bit smoother so thats good.. Still thinking of cleaning out the EGR valve and ports though im it doesnt sound like it is too easy.. some say it is some say not so... the motor is f22a6 and i found that this has a two stage intake ... could it have something to do with this?
gdimattia
11-30-2014 09:02 PM
boseafuss
12-30-2010 12:40 PM
tiredredcoupe
11-13-2009 06:17 PM
porcorosso
02-13-2008 07:34 PM
HAphil
07-21-2006 11:27 AM
Quick Reply: Poor acceleration
