02 LX v6 p1298 stored but no check engine light
Hi I have a lx coupe that has a sputter/hesitation at around 3500-4000 rpm. Almost as if the trans is slipping. I scanned for codes just in case, and found a p1298 stored. i looked at the fuse in the ip fuse box. its good. Im at a brick wall and dont even know if the sputtering has to do with the eld or not...Someone please help!
P1298 = electrical load detector
P0336 = crankshaft position sensor
Each code isn't a guarantee that it's a bad sensor. A dirty/loose/corroded wiring connection can also cause these codes.
I would think the ELD cannot cause the sputterring. It's job is simply measuring the electrical loads so your ECU can decide when to shut down the alternator.
proton8d
09-09-2013 06:05 PM
brandon0409
09-08-2013 11:05 AM
Aathavan
07-14-2011 10:24 PM
78gaw
01-20-2010 09:45 AM
