Power Window Issue
Old 11-05-2007, 03:33 PM
mfagan
Default Power Window Issue
I have a ? concerning issues with the drivers side power window on my 97 Accord EX. I believe the motor may be on its last leg again. The window has always been sluggish even after replacing the motor a couple years ago. It usually makes it half way and starts clicking and then sometimes stops. It seems worse when its colder outside and also worse when sitting with engine off as opposed to cruising at speed. This make me wonder if its a switch issue sometimes rather than the motor itself. Any suggestions? Thanks.
Old 11-05-2007, 03:44 PM
sir_nasty's Avatar
Default RE: Power Window Issue
sounds like either an adjustment, dirty track or motor issue, I don't think it's the switch. I think that your track is mega dirty and that's why it still rolled up so slow after replacing the motor. That in turn put extra strain on the new motor and frayed the wire cable. Check out our DIY section I have a writeup on replacement if you want to do it yourself
00AccordLX5spd's Avatar
Registered User
I would clean the tracks before doing anything else: https://www.hondaaccordforum.com/m_77869/tm.htm
Old 11-05-2007, 03:56 PM
mfagan
Thanks for the responses. I'll try a little cleaning and lubricating of the tracks first and see if that seems to help. Then maybe I can make a judgement call on a new motor improving the situation. I'm a cheapskate do-it-yourselfer on most things and replaced the motor/regulator with an aftermarket replacement from the internet last time around. I don't mind the work and can usually figure out how to get the job done.
Old 11-05-2007, 03:58 PM
sir_nasty's Avatar
if it is the motor get one from 1aauto.com, they're cheap, high quality and lifetime warranty.
jkeely
05-02-2012 03:48 PM
Opballer
02-09-2012 11:54 PM
mrpetemd
09-17-2011 04:13 PM
zZHellBlazerZz
06-15-2011 10:12 AM
mmazb3
11-26-2007 03:16 PM
Quick Reply: Power Window Issue
