Sponsored by:
Sponsored by:
Power Steering Whine on Cold Mornings
Old 11-06-2007, 10:42 AM
dkchatterton
Default Power Steering Whine on Cold Mornings
94 Accord 6 Cylinder
Last couple of mornings, my power steering has been harder to turn and makes a really loud whining noise. After it warms up, it seems to be fine. I checked the PS fluid level and it was fine. I put about another ounce into bring it up to the full mark. This morning it was whining again and when I looked, it had bubbled up out of the top of cap. Any ideas? I can't get an appt. with my mechanic until about a week out and don't want to damage if serious. Car has about 60k miles on it.
thanks for your help.
Old 11-06-2007, 10:50 AM
sir_nasty's Avatar
Default RE: Power Steering Whine on Cold Mornings
is the belt good? Are you using honda PS Fluid? does it leak at all (aside from bubling over)
Old 11-06-2007, 11:34 AM
Fenix's Avatar
i had the same problem, turned out my steering rack needed to be replaced. Your describing all the same symptoms i had.
Old 11-06-2007, 02:48 PM
dkchatterton
I am using Honda Fluid and no, there appears to be no leaks.
Don't like the sound of replacing the Rack -- how much did that run you?
TrinDawg38
03-21-2012 05:58 PM
flpilot83
03-07-2009 08:11 PM
vernmont
10-11-2007 02:42 PM
K@rl
09-28-2007 02:57 PM
kulu
11-20-2006 09:39 PM
Quick Reply: Power Steering Whine on Cold Mornings
