power windows
Old 08-25-2014, 12:12 PM
vicmgon's Avatar
Default power windows
I have a 97 accord ex with a power window issue that i can't figure out. First, all the windows except the driver's side window are working. So I thought let me check the fuses and the relay and I did and they were ok. Then I thought it was the motor so I changed it. but nothing. Then I changed the switch to see if that was it but the window doesn't move. Not sure what else to check.
Old 08-25-2014, 12:56 PM
Check that 12V and ground is being routed to the motor by switch panel. A wiring diagram (see DIY forum for Online Manuals links to download manuals). It could be damaged wiring or connector to the driver's window motor.
Old 08-25-2014, 02:16 PM
Moved to the question and answer forum for you..
Old 08-25-2014, 07:35 PM
Check the wires in the door jamb, usually it is due a ground wire that goes through there. Relatively common problem.
Old 08-27-2014, 05:47 AM
vicmgon's Avatar
Thanks will check all suggestions
falge
03-11-2008 06:47 PM
th22ek9
09-13-2006 11:11 PM
th22ek9
09-08-2006 09:07 PM
smoovekriminal
04-22-2006 12:28 PM
sir_nasty
03-15-2006 05:31 PM
Quick Reply: power windows
