Sponsored by:
Sponsored by:
Q. re: bleeding brakes vs. ABS system
Old 09-01-2012, 12:41 PM
Pajamarama's Avatar
Default Q. re: bleeding brakes vs. ABS system
Hello --
I am looking to replace the brake fluid for the car listed in my sig.
I have been reading the Helms manual to find information on this process. The Brakes section has 2 sub-sections: Brakes and ABS.
I've been trying to figure out how the two sections correlate in regards to bleeding/fluid replacement. Do I bleed all the individual brake lines first and then the ABS reservoir, or the other way around? Any input on the correct order would be appreciated. Thanks.
Old 09-01-2012, 01:18 PM
Personally, I would probably do the ABS first, but I do not think the order would matter much.
Old 09-01-2012, 03:21 PM
What Accord? They have different systems in later models.
Up to about 1997 they had a reservoir. You could remove/refill the fluid and not require any bleeding, but would leave a small amount of old fluid in the modulator. If you progressively crack the bleeder, you should remove all the old fluid.
Bleeding main brakes w/ ABS is same as non-ABS; replace reservoir fluid and progressively bleed each while while topping up reservoir as necessary.
Wrenching
08-01-2014 06:13 PM
big boi
01-13-2014 08:33 AM
deserthonda
03-30-2013 01:11 AM
AngelFisher27
06-21-2011 08:32 PM
BlueByYou
10-08-2006 01:43 AM
Quick Reply: Q. re: bleeding brakes vs. ABS system
