Sponsored by:
Sponsored by:
Radiator tank Overflow.
Old 08-27-2010, 04:12 PM
desfam5's Avatar
Default Radiator tank Overflow.
Homda accord lx 94
Is is usual for the radiator coolant holding tank to overflow? I filled it to the top level, and screwed down the cap. I drove it for around 5 miles, and then I switched the engine off. I heard this gurgling and bubbling sound, and I saw that my holding tank was overflowing. What could be wrong here?
BTW Can somebody please tell me where the thermostat is? I looked into the 2 bolt flange on the approx 2" hose coming off the radiator, and there was nothing in there. No Thermostat. Is it located somewhere else??
My cooling system has a leak or problem somewhere. Ever since I replaced the radiator, it has never worked perfectly.
Old 08-27-2010, 04:30 PM
The thermostat is located where the lower radiator hose connects to the engine. The thermostat housing has a bleed valve on it and also a coolant temp sensor on it.
When you refilled your coolant, did you bleed the air from the system? That could cause all kinds of strange problems.
bluedemon
12-14-2014 10:58 AM
camman
08-04-2013 01:41 PM
faran
07-14-2013 01:55 PM
mjhenks
02-11-2010 07:40 AM
blackex19
04-16-2007 05:06 AM
Quick Reply: Radiator tank Overflow.
