95 Accord starts but immediately dies... help!
I have a 95 accord v6 automatic. havent had too many problems with it. now it will turn over and start for a split second and then it dies. i don't even know where to start to find the problem with it. a guy i work with thought it could be the neutral saftey switch.. but i really wouldn't know..
any info would help..
thanks
thanks
ya the fuel pump primes..you can hear it plane as day when you turn the key to II. no check engine light..
ya as soon as you think its gonna start and run and let go of the key it dies.. i actually was messin earlier and if you hold the key to where the starter is keeping the motor turnin over it runs.. what does it mean if there is no juice to the blk/yel wire.. i just got off work so i will have to check it in the morning..
could it be anything to do with the distributor? my grandpa said it sounds like it could be gettin moisture in the distributor or something..
i will have to check it out on my next day off.. thanks for helpin!
My pleasure.....I'm 99% sure it is the switch, just always want to test before replacing.....no power to the BLK/YEL at the dist, the key switch isn't "sending" power, or a broken wire.
Good luck, let us know how it goes.
