Sponsored by:
Sponsored by:
Rear upper control arm BOLTS
Old 06-05-2008, 03:35 PM
zero5's Avatar
Default Rear upper control arm BOLTS
96 LX non-vtec
I need the pitch for the 10 x 45 bolts that go in the Rear upper control arms. I may have to tap the nut.
thanks,
Ben
Old 06-05-2008, 05:30 PM
zero5's Avatar
Default RE: Rear upper control arm BOLTS
96 Accord LX incase I wasn't clear
Thanks
Old 06-05-2008, 09:01 PM
hondadude's Avatar
why not take the bolt with you when you go to buy the tap?
Old 06-05-2008, 09:39 PM
zero5's Avatar
I don't know what the correct bolt is. Someone installed a Bolt & washer Camber kit with an Air tool. It seems they messed up the nut pretty bad. Honda says the stock bolt is a 10x45 but they don't know the pitch.
cukaracha
09-14-2014 11:09 PM
jkowtko
12-20-2013 05:29 PM
JohnNH
11-05-2013 02:50 AM
curvenut
01-31-2013 08:36 PM
GodAmAccord
04-15-2006 01:23 AM
Quick Reply: Rear upper control arm BOLTS
