Remove center console - Honda Accord Forum - Honda Accord Enthusiast Forums
Reply
Thread Tools Search this Thread
Old 09-18-2007, 03:24 PM
Default Remove center console
Hey all,
How do I remove the center console in a 99 Accord EX V-6. I have taken out the four screws in the back and also pulled the cup holder and shifter handle. I have also removed the bezel around the gear selector. It still feels anchored. I'm sure there's just another plastic piece to be removed so I can access screws. But, if I don't get it right, I break off tabs and then everything is loose from here on.
Thanks,
Dale
Old 09-18-2007, 03:56 PM
Default RE: Remove center console
Try hondaautomotiveparts.com, put in your car's particulars & look under 'console' or something like that. It'll probably help to have a parts drawing.
You mighthave to remove the lower panels on either side (under steering column & under glovebox). There's a couple hidden screws there. Also I think you have to pull up the bottom of the storage box for another pair of screws. It's been awhile since it did this...
Then again... I understand there's a Helm manual in the for-sale board...(j/k)
Old 09-18-2007, 04:21 PM
00AccordLX5spd's Avatar
Registered User
This is in the DIY section:
http://www.hondaaccordforum.com/Grea...m_41104/tm.htm
Click on the first link in dh's post and follow his instructions on logging in. This site takes you to an exact copy of a Chilton Manual for almost any type of car. It shows how to remove the consolefor your car.
Old 09-18-2007, 04:26 PM
Registered User
Quote:
ORIGINAL: JimBlake
I've been trying to pimp your Helm over on 6thgenaccord.com. I guess you must not have gotten any bites yet.
haha! Post #1000! I'm such a
Old 09-19-2007, 10:07 AM
Registered User
OK so I got bored last night and looked at my Haynes. I read what you already did, so I hope this explains the rest of the procedure. There are 4 screws inside the console itself. I don't know if you meant those were the ones you removed already or not. There are also 4 screws (2 on either side) at the front of the console (past the gear shifter) close to the floor. All must come out to remove the console.
Reply
Thread Thread Starter Forum Replies Last Post
Remove dirt/wear from center console accordlover9696 Detailing 5 10-01-2012 07:30 AM
Remove Center Console Lid ltdanp21 General Tech Help 5 07-12-2011 09:15 AM
Center Console removal MALSR General Tech Help 2 11-02-2006 11:49 AM
How do I remove window switches in center console johnc General Tech Help 4 03-06-2006 05:14 PM
2002 accord center console light itsmetinh Audio/Visual Electronics 0 01-01-2006 11:42 PM
Tags
2000, 2009, 99, accord, accors, center, console, disassembly, edge, ford, honda, lx, middle, parts, removal, remove, removing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
