Sponsored by:
Sponsored by:
Remove and reassemble entire passenger door
Old 03-23-2017, 11:06 PM
joevdburg's Avatar
Default Remove and reassemble entire passenger door
Hello,
I wondering if I can remove the entire front passenger door and then bolt it back on without creating any big issues. I am very worried the door will not align properly, but also assuming there are some pretty tight alignment pins which could make the task easy.
(2005 Accord Sedan)
Thanks in advance for the help. - Joe
Old 03-24-2017, 03:52 PM
The Toecutter's Avatar
Originally Posted by joevdburg
Hello,
(2005 Accord Sedan)
I din't know about alignment pins, but if you take your time and have a helper you should be able to get the door back where it was. Use the "witness" marks from the bolt heads to help you get in alignment is the best advice I can give you, as that's worked for me on resto work over the years.
MessAround
05-16-2014 11:35 PM
USEDBLACKSTAR
09-12-2012 10:02 PM
dunnskii
01-14-2011 09:27 PM
vipjdm-Justin
01-13-2011 10:49 AM
elgwedoloco
West
11
12-13-2010 03:01 PM
Quick Reply: Remove and reassemble entire passenger door
