Replace timing belt on 2001 honda accord V6 sedan
Hi guys
I'm in a process of replacing the timing belt for my 01 v6 sedan. I'm stuck at the power steering belt and Crank shaft pulley and have a few question.
1)Do we really have to remove the crankshaft pulley or is there another way around it to remove the timing belt cover?
2) We can't adjust our alternator belt because the belt has automatic tensioner but can we adjust the powersteering belt?
I'll post the DIY for this after i'm done. I've search around and it seems like there are alot of DIY for V4 but none for V6 model. Any one has any ideas please help. Thanks
forgot what the 3.0 p/s pump looks like but there is an adjustment . probably right on the pump. you take the p/s belt off before you pull the crank pulley . first make sure you can get the crank bolt off . keep the car in running condition in case you have to drive it some where to get the crank bolt cracked free.
You will have to remove the crankshaft pulley.
I recently used heat (propane torch on bolt head) and air impact (1/2" ingersol rand) to break bolt on Acura MDX 3.5L V6 which is somewhat similar to your engine.
It seems you don't have much experience or guidance. Suggest purchasing a shop manual from automanualsource on ebay for $21.99. He has one for your model. Easy to use and OEM manual.
PS Pump and serpentine belt tensioner must be removed.
Check youtube for a video on your engine. Probably anything in 98-02 would provide insight to your job.
Hi guys
When I did the timing belt, I used the starter blip method to remove the crankshaft pulley bolt. I retightened it with the crankshaft holding tool so that the engine wouldnt spin when we torqued it. The most time consuming part was for me was removing/installing all the dang bolts to get the timing covers off. Another difficult part, that I would avoid, was we bled the coolant from the engine block as well as the radiator. There is probably a better way to do it then the way we did it. The engine was also supported on by a block of wood held up by a floor jack since the side engine mount was removed. We had to play around with the engine height at times to be able to access stuff.
We changed the timing belt, ps pump belt, accessory belt, water pump, antifreeze (of course), and timing belt tensioner. If I had to do it again, I would have also changed out the timing belt idler and tensioning pulleys. I think some ppl also change out the cam and crank seals but I didnt. You should at least inspect them I believe.
