Reset ECU or SRS Light?
Old 08-01-2008, 09:46 PM
toicy4ya's Avatar
Default Reset ECU or SRS Light?
Sup guys,
I have a 06 honda accord ex, how do you reset the ecu or SRS light?I read the sticky but didnt understand the following part, "jump the SRS ( MES) connector ( MES = Memory Erase Signal ,) using the scs connector or paper clip". How do you do this?The SRS light is on which i believe is due to a bad buckle that i will be replacing.
Thanks
Old 08-02-2008, 11:56 AM
hondadude's Avatar
Default RE: Reset ECU or SRS Light?
It means, very simply, put the connector/paper clipinto the terminals of the plug.
Old 08-04-2008, 08:52 AM
Wouldnt that be covered by warranty? Seatbelts & airbags have a much longer warranty than the main bumper-to-bumper warranty.
Old 08-06-2008, 05:11 PM
JKobielusz
i had this problem with my 96 accord and I took it to a honda specialist, he plugged his little hand held code reader into the terminal under the ashtray, 30 seconds and $20 later the light was off. Not sure if that holds true with newer hondas, but some things dont change.
Hope that helps.
Old 08-06-2008, 05:28 PM
falkore24's Avatar
My 2000 had a buckle replaced for free.
Hondalover
03-05-2011 09:57 AM
jtnixit
01-30-2010 08:27 PM
wish234
03-15-2009 03:32 PM
Busareds
06-26-2007 05:50 PM
adbraz
09-29-2006 07:00 PM
Quick Reply: Reset ECU or SRS Light?
