RPMs shoot down, car sounds like its going to turn off. long ongoing issue pleasehelp
I have a 1995 accord lx, auto. I will start by giving some detail on the problem, back in early december my tranny was acting up, I had to get it inspected so I just told them to check it out, they found nothing wrong and said it drove fine. The next day my tranny went on me after only driving for about 20min. I had it worked on that week, it wasnt "finished" till about 3wks later. Since they told me it was finished it has been having a new problem everytime, or a re-occuring one (all within about 2-3 days after getting it back from them) Everytime I took it back there and they were done working on it, something else would happen. ( I had no problems with this car in the 2yrs I had it prior to taking it there for my tranny)
The problem I am having now (same as one I had before) is as I am driving my rpms will shoot down some at random times and it will sould like the car is goin to shut off. Before when it did this is would shut off so I had to just drive it home so it wouldnt get stuck.
I have told the garage about this and they told me they have no idea what it could be after they checked several things in the past. I am out of ideas, and already have put 1000$ down for my tranny, now I have another problem.
If anyone could let me know if they think this could be related to them doing my tranny (I dont see how it wouldnt be) or if anyone has ANY ideas of what to check that would be great. Thanks.
The quickest test is to get CEL and TCU codes. Read the thread called How to get CEL codes in the DIY section. Count both the check engine light and the D4 light flashes. Post any codes you find on here.
Did they tell you what had to be replaced each time you brought it in?
Please reply with any suggestions..
I have a 95' Honda Accord lx(approx 177k). I have been having this problem for around 6months now.
It started with my transmission acting up, I knew something wasnt right but my inspection was soon due so I just took it to get inspected and told them about the suspect tranny problem. They looked at it, drove it awhile, and gave me a passed inspection telling me that my transmission was fine. The next day my tranny took a crap.
I decided I wanted to have it rebuilt (yes its high mileage but IMO it worth it for the money I put in.)
I had it rebuilt and the tranny was fine but ther was a problem with the rpms. They would fluctuate about 3000rpm up and down. (dont know exact no. that it is between) I had the car looked at at the same shop that rebuilt the tranny and they checked in, replaced a wire for the alternator, replaced the battery, checked ignition module;coils. I have had the car in there at least 5 times and was told it didnt act up for them and basically it was fixed, and each time it continued to act up intermittently.
After multiple times taking it there I decided to take it somewhere else. This place looked at it alittle and told me I should have my g-wire for my engine block replaced. I had that replaced and drove it for over an hour that day and it drove perfectly fine(normally it would act up in ten min) since that I thought it was fixed and drove it about 2hrs untill it acted up again while i was idling. it was just a few seconds then stopped and i drove it for 30min and it drove great. it hasnt been acting up as much but still does the same thing when it does. the lasttime it acted up I noticed my battery light flickering on and off and it seemed as I accellerated more or went up and incline it brightened and stayed on more often. After that the rpms would jump up and down and it sounds like the car is going to shut off.
Yesterday I tried taking it out for a drive and when drove about ten yds to pull out lot it shut off. The battery light and oil light were on and car was off. The headlights, radio, neons, gauges all stayed on. I turned the key off and started it bac up. It started right away and when I went to back it in spot when I hit the brake it shut off again right away.
Please anyone that could help with any ideas that would be great this has been a long stressfull stuggle with this problem.
Any other information that could help just ask. thanks.
I stated that near the end of the post. It happens whenever. Also, the battery light flickers. My transmission was worked on in december and since then I had problems with the rpm fluctuating. This happens sometimes while idling in park or drive, and when I am driving at any speed.
It sounds like you have air in the cooling system. You may want to drain the coolant into a clean container and open up the bleeder valve when you refill. Google the term below to watch a video on how to do this.
zUpXgAJ1gjU
The stalling when hitting the brakes sounds like something up with a security system. Does you car have a security system?
Since the battery light turned on, I would disconnect the battery and clean all ends of both battery cables. Then reattach. If the battery light returns, I would have the battery/alternator/starter tested at the parts store.
zUpXgAJ1gjU
Stalling with the brakes might be the vacuum booster being a vacuum leak?
Disconnect the large vacuum hose to the brake booster. Plug the side going to the engine so no air can go to the engine.
The brakes will suck, they will need lots of muscle, so be careful. Drive around the block or something safe, and see if that fixes the stalling. If so, there's something wrong with the brake booster or a vacuum leak in that hose.
I have a 95 accord lx, auto,
My rpms have been fluctuating ever since I got my tranny rebuilt back in december. It has been better as of late, but still happens. I noticed sometimes when I hit the brake the car shuts off, but starts back up no problem. Yesterday I was backing out of a spot, and when I would put it in drive it would shut off. I would turn the key and turn it back on, it would start fine, but when I would put it in D4 it would shut off. ((this problem stopped after about 3 tries.)) It then drove fine the whole way home.
I have been trying to fix this problem for awhile now, and had it at 2 separate garages.
(Alternator is good, battery is brand new)
