Rusted Motor mount on a 200O Accord
I have a friend that has a 2000 Accord where the lower rear motor mount has broken away from the frame. I was supprised that it would happen. Has anyone else had this happen? My friend took it to the Honda dealer and the quoted $3500 to repair the car that is only worth $3000. What a joke. Anyway, my son has a 1996 Accord and his motor mount are fine.
Was car a 4-cyl or V6?
V6 probably requires lowering subframe to access mount. However, $3000 sounds way over the top for this job. Suggest getting quotes from several shops specializing in Honda/Acura work.
Yep. I found this out this afternoon that there is a problem with premature rusting on the left rear part of the engine cradle. The problem is that the AC drain is right over this section of the cradle and it is identifed as the cause becasue it is constantly wet during summer months. In 2003, Honda moved the drain, but neglected to tell people that earlier cars would be effected. Unbelievable. Hell they could have done a cheap fix of just undercoating that area and helped people out but instead that were silent on the subject.
dealer is not going to put in used parts unless they cannot get new or re-man ones (unlikely)
komar
05-11-2013 10:33 PM
baer77
02-27-2009 03:47 PM
