H22a wiring
H22a wiring
Hey guys im doing a h22a jdm obd1 swap on my 96 accord f22b1
And im having a little trouble with the wiring bcause the plug on the accord
Only has 5 wires n the h22a have two plugs with 10 wires how do i
Go about wireing this if you anyone can help me out i will appreciate it and one
More thng what do i do with the crank sensor plug? Thnks
The left ones are the ones you need to use. Assuming you have the two for the wiring harness to match.
Then just run the wires from the timing case to the distributor and wire it up according to that diagram.
Jahsaccordcoupe
11-14-2007 10:56 AM
