Stereo + Dash clock quit after bump
Old May 25, 2013 | 07:02 PM
Clayknoll's Avatar
Default Stereo + Dash clock quit after bump
Hey there don't know how to change my signature but my ride is
a 1989 Honda Accord LX 4 door I switched the stock deck to a new pioneer cd deck and was installed properly no problems then a few months later I went over a railroad track (a few times a day usually) and my stereo power was out and so was my dash clock which previously worked fine. all fuses are still good, same with visible wires
my question is, is there other wires that could come loose(maaybe not visible) that would make my clock and stereo both die from a bump
Old May 25, 2013 | 10:31 PM
kayweb's Avatar
In short: yes.
Have you pulled the deck yet?
Old May 26, 2013 | 09:34 AM
I stuck "something" in your signature.
As stated, pull the radio - not hard at all on these - and verify you are getting voltage when the key is on, if not we can start working back.
Old Jun 18, 2013 | 08:30 PM
Clayknoll's Avatar
Not sure what pulling the deck/radio means like i had the deck in but took it out a bit after the electric failed, is there someway i can pinpoint the problem or get to the internals in a safe manner without spending 120+ just to have someone look at it.
how do i test voltage like hook a meter to a certain wire?
Old Jun 20, 2013 | 05:34 PM
Yes there is a fuse you can check....then with a test light or volt meter you can check some wires.
I have to ask, was the install done with an adapter or was this a cut and splice into the factory wires?
Push the "button" on the clock and see if it tells the time? You can push the plastic piece to the right - kind of at the top - or pull it down and press the little black button/stub at the top with you finger.
Double check the #2 10amp fuse in the drivers under dash fuse box.
Old Jun 21, 2013 | 07:07 AM
Clayknoll's Avatar
No cutting was done with stereo just a simple plug in and play
And this weekend ill check her out thanks for info
Tony1M
Nov 6, 2023 08:29 PM
Punkfarterrrrr
May 24, 2011 03:18 PM
TOMMYgunn017
Mar 7, 2011 01:00 PM
RuthlezzFL1P
Jun 5, 2008 11:55 PM
old88dog
Jun 13, 2007 10:58 PM
