Sponsored by:
Sponsored by:
Radiator fan trouble..
Old 03-27-2012, 04:16 PM
cvrocafella's Avatar
Default Radiator fan trouble..
Hi I'm having problems with my fan, 94 accord ex..was working perfect 1 week ago, now it doesn't come on. The fan works if I run it directly to the battery, my car was overheating so I thought my fan went, since it's not that, we bought a new thermostat, ect sensor, also I think it's ac relay under the hood by the fuses, still no fan - we tried jumping the green connector looking thingy, there's 2 of them on the left side of engine, sorry I don't know much about cars, any help/suggestions would be much appreciated thanks..
Old 03-27-2012, 05:31 PM
crispin's Avatar
do a search for radiator fans on this forum
it has been covered many many times in detail and there are easy to follow instructions on how to find what is wrong and fix it.
Old 03-28-2012, 06:19 PM
Crispin is correct, there is also a post by Jim in the "Common DIY Threads" sticky at the top of this section describing the sensors and their function.......I'll give a slight hint.
Green connector near the t-stat housing, lower hose. Key to on-engine does not need to be running, pull the connector off, use a paperclip or something and jump the "wire connector" side of the connector. BOTH fans should come on.
BigRoach
06-03-2013 01:54 PM
Novaknowledgenow
05-30-2013 08:58 PM
hmr
03-28-2012 10:49 PM
honda-afford
03-28-2012 08:47 PM
daddy
02-06-2006 02:52 AM
Quick Reply: Radiator fan trouble..
