Temperamental reverse lights
Old 09-28-2014, 09:50 PM
Bforbesut's Avatar
Default Temperamental reverse lights
94 accord 5 speed, reverse lights come on when it is almost in gear but not quite but then turn off when I get it all the way into gear. Any ideas?
Old 09-29-2014, 09:43 AM
Probably an intermittent transmission reverse switch. You can short the connector to the switch and confirm light stays on all the time. Fix by replacing switch unless an intermittent circuit is discovered.
From shop manual it's on top of trans underneath lower radiator hose. You will likely need a deep socket to remove.
mclrh2o
09-17-2010 05:45 PM
pbplayer257
06-17-2010 11:15 PM
Stoenr
01-29-2009 03:24 PM
Allmetalweaver
07-03-2007 08:17 PM
waynewonder
12-20-2005 03:43 AM
Quick Reply: Temperamental reverse lights
