Sponsored by:
Sponsored by:
Rough '96 needs help
Old 03-28-2011, 01:55 PM
bruce's Avatar
Default Rough '96 needs help
I have a 1996 Honda Accord that is in pretty rough shape after driving in Naples, Italy for 3 years. Currently in Germany but plan to move back to the U.S. this coming June. Will sell the car to a used (junk) car buyer before leaving. Unfortunately the car flunked the annual inspection because the SRS dashboard light was on. What is the easiest, cheapest thing I can do to pass the inspection and drive until June?
Old 03-28-2011, 03:16 PM
Adler's Avatar
That depends on why the SRS light is on... First thing to try is reseting it, often this fixes the problem. Do a search on here for how to reset it. Its been covered at least a hundred times.
If reseting does not work, you can pull the codes from it and it could be something as easy as a belt buckle or as hard as the SRS unit.
Jesus Pickles
04-29-2012 08:44 AM
mamtsberg
03-17-2010 09:15 PM
dhg2496
04-19-2008 08:41 PM
mikes
10-23-2005 10:34 PM
RoX
06-24-2005 05:47 PM
Quick Reply: Rough '96 needs help
