Need timing belt
Dealership price will vary depending on your area due to different labor rates. Many dealerships I know of will charge around $700 or more. Some may be less depending on your area. Generally, the tensioner(s) and water pump should be replaced at the same time. On earlier model Accords, it is recommended to change some of the oil seals (e.g., cam seal, crank, seal, etc.) at the same time; but, on your generation Accord, many Honda techs' opinion is that the seals don't leak that easily and many techs don't change them during the time belt change for your generation.
5.0stang
04-23-2013 06:37 PM
